Logs out the session of a current user for CLI or Telnet.
N/A.
Use this command to log out of a CLI or Telnet session.
When you issue this command, you are asked to save your configuration changes to the current, active configuration. Enter y if you want to save your changes. Enter n if you do not want to save your changes.
The following command logs out the session of a current user for CLI or Telnet:
exit
A message similar to the following is displayed:
Do you wish to save your configuration changes to primary.cfg? (y or n)
